Discussion topic: Multiple Devices
This message was authored by: theaaj
Message posted on 10 May 2026 05:24 PM
Multiple Devices
Sky Max Hub is worse than Sky Hub for Fibre100. Can't run multiple devices speed is rubbish. Everything keeps buffering. Need a fix or a booster please.
Find out more
Message posted on 10 May 2026 05:30 PM
Re: Multiple Devices
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
