Discussion topic: Mrs Robertson
This message was authored by: Tracey3289
Mrs Robertson
My WiFi  is not working properly at the moment  u need to sort it out
Re: Mrs Robertson
@Tracey3289
Not us. You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
