Discussion topic: Mr turner
Message posted on 07 Jan 2026 08:04 PM
Mr turner
Internet keeps dropping out ?
Message posted on 07 Jan 2026 08:21 PM
Re: Mr turner
@Dan2551
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
