Discussion topic: Mr jo
Message posted on 26 Mar 2026 08:26 PM
Mr jo
Do you have a problem with internet in Trumpigton?
Message posted on 26 Mar 2026 08:29 PM
Re: Mr jo
@Jaro-
You haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
