Discussion topic: Mr iannone
This message was authored by: RM1616
Mr iannone
No WiFi just 2 green lights on  orange flashes unplugged for 5 mins re setup but still the same
Re: Mr iannone
@RM1616
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
