Discussion topic: Mr Anthony Watson
This message was authored by: Tonywats
Mr Anthony Watson
Why has my broadband keeps lossing WiFi and it keeps saying my connection as dropped as well.
Re: Mr Anthony Watson
@Tonywats
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
