Discussion topic: Mr Andrew Ward
Message posted on 01 Feb 2025 07:05 AM
Mr Andrew Ward
Is there a problem with the internet in my area
Message posted on 01 Feb 2025 07:10 AM
Re: Mr Andrew Ward
No idea. We are customers like you,
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
