Discussion topic: Moving Router and tv
This message was authored by: Robbo591
Do sky move cables , router, and sky tv box to support rearranging living room?
Re: Moving Router and tv
@Robbo591 they may move satellite cables if asked but they may charge. While they can move things like a master phone socket to allow a hub to be moved  but normally given Q boxes can connect using WiFi moving the hub is not necessary. If you do want to move the hub yourself you can easily buy a longer cable to connect to the phone socket or ONT if you have full fibre. Moving an ONT itself is not trivial as fibre cable is very delicate.
This message was authored by: Doc5907
@Robbo591  if you're not comfortable rerouting the satellite and Ethernet cables I would get a local (to you) electrician or satellite/broadband engineer.
Sky Q 1TB UHD
LG TV
Sky Mobile
