Discussion topic: Moving ONT fibre box
This message was authored by: A712
Message posted on 27 Jun 2025 10:00 PM
Hi, I've recently moved into a new build and the only ONT box is in the attic (for some weird reason) My office and living room are both on the ground floor, so running Ethernet cables or setting up a mesh network isn't ideal.
Would it be possible to move the ONT box to the ground floor instead
Find out more
Message posted on 30 Jun 2025 12:11 PM
Re: Moving ONT fibre box
Hi @A712
Yes you can get this moved by booking it through Sky, note that it would usually be at cost to you though
I am NOT a Sky Employee
