Discussion topic: Modem keeps cutting out
Message posted on 24 May 2025 07:00 PM
Message posted on 24 May 2025 07:24 PM - last edited: 24 May 2025 07:30 PM
Re: Modem keeps cutting out
@Jamieg85 When the hub cuts out from the Broadband do you see any indication by the hub light changing colour?
If you also happen to be on a FF connection, then the led's off the ONT at the fault period also!
Message posted on 24 May 2025 07:33 PM
Yes I have sky max has a white light in centre when working correctly and red light when hub can't access Internet or connection is lost.
At least 3 times in last 24 hours the light has been on red for an hour or more this is a problem for me as I have WiFi security cameras
Message posted on 24 May 2025 07:36 PM - last edited: 24 May 2025 07:39 PM
@Jamieg85 And do you have a FF full fibre connection! For the red light as below also.
Sign in to Service Checker and we'll run tests on your connection and setup to find the issue, then show you quick steps to help fix it.
Not the account holder? Try our simple steps to try get you back up and running.
