21 Jul 2023 09:23 PM
My router
Model Number: SR203 is really close to the main junction box and has bog standard modem cable connected. I wondered if I get a much better cable will it help speed etc and what one should I buy? I recently bought a short cable that fitted both but didn't work at all so reckon it was the wrong one. I recently got a Sky Glass 65 inch and trying to set it up to the best way I can. Junction box is a bit closer than the cable supplied by Sky. Don't know exact distance but one same length would do or slightly shorter.
21 Jul 2023 11:04 PM
Putting ethernet cable (standard Cat5e) between the Hub and the television rather than using WiFi may well be beneficial.
21 Jul 2023 10:54 PM - last edited: 21 Jul 2023 11:05 PM
The speed of FTTC is directly related to the 'phone line' distance from the fibre cabinet to the subscription address: any internal cabling between Openreach socket and Hub is of negligible length compared to that, and 'better' cable would almost certainly make no difference at all.
