Discussion topic: Mobile phone
Message posted on 12 Jun 2025 08:13 AM
Mobile phone
Message posted on 12 Jun 2025 08:20 AM
Re: Mobile phone
@Giggles75 try the following tell the phone to forget the Sky connection then power down and reboot it and try again which usually works as the rebootveill clear the memory position which stores the password which sounds to have become corrupted.
Message posted on 12 Jun 2025 08:53 AM
Re: Mobile phone
Thanks for your advice, unfortunately it hasn't worked 😕
Message posted on 12 Jun 2025 09:09 AM
Re: Mobile phone
@Giggles75 What is the sky hub model that you are trying to connect to, and also the model off the mobile?
Message posted on 16 Jun 2025 09:35 AM
Re: Mobile phone
- Thanks everyone,unfortunately nothing worked and sky sent me out a new router and now all is good.
