Discussion topic: Missing pieces
This message was authored by: Cel
Missing pieces
Good afternoon,
I have been advised by Openreach to contact you regarding arranging a engineer to visit due to a missing piece from our broadband connection.
Re: Missing pieces
@Cel
This is a customer ▶️ customer discussion forum where we try to help other customers. You haven’t actually contacted Sky by posting on here.
Any particular clue as to what it is?
Avatar for Cel
Level 0 icon
Re: Missing pieces
Apologies!!! I did not notice 😂
I will try and see where I can go to contact sky directly.
hope you have a lovely rest of the day!
Re: Missing pieces
@Cel
These are the current methods for contacting Sky. Some contact methods will be more appropriate than others depending on the issue you have.
🟡 📞 Call Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟡online help via this link
https://www.sky.com/help
🟡Sky Assistant 💬 should also be available via
🟡Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
⚪️Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed over a weekend.
