Discussion topic: I'm having problems with my connection
This message was authored by: Katarzyna84
My internet from yesterday doesnt work, please help me sort this out, this happen not first time... I think abou give up with the sky
Moderator note: personal information removed
Re: Miss Cieslak
@Katarzyna84
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
