Discussion topic: Middle light orange
This message was authored by: Yesman
Middle light orange
My WiFi has just cut off and I have an orange/amber light in the middle. I've tested connection and it says there and no known issues within the area. Reset it twice and still flashes orange and the goes solid. Any advice?
Re: Middle light orange
@Yesman
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
