Discussion topic: Message from openreach
This message was authored by: Cmcg08
We recieved a message from open reach to confirm activation on new broadband. However Sky messaged to say that activation is done remotely so there would be no engineer. Can someone tell me if this is a scam or legit i don't want to reply anything just incase
Re: Message from openreach
@Cmcg08  Most activations are done remotely so the text from Sky is real to tell you that your broadband should be enabled.
Avatar for Cmcg08
Level 0 icon
do you know if the message from openreach is legit.
@Cmcg08  Are you getting ultrafast broadband installed and do already have an ONT installed?
@Cmcg08
It is a remote activation. Where in that text does it say an engineer is coming?
It is a legit message, just reply confirm if you know that the ONT has a power cable and does power up.
I am NOT a Sky Employee
@Cmcg08
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
This message was authored by: AndyStephens
I had the same message a couple of weeks ago (except I'm moving from Sky to Vodafone). The switch has been arranged for the end of this month, but it's not clear whether I have to reply "confirm" now, or on the day of the switch. What did you do?
This message was authored by: Paul8888
I have received the below via text from a mobile number, just want to check if genuine???
Your engineer visit is on Fri 05 Jul between 1PM - 6PM at postcode ending 1LT.
Top 2 things to know:
1. Our engineer will drill a small hole into your building to connect your Full Fibre Broadband. Because of this, we need a decision maker aged 18+ to be present.
2. If you rent the property, you'll need the landlord's permission for the work to go ahead.
Reply YES to reconfirm or CHANGE before 4pm tomorrow if you need to reschedule.
@Paul8888
Have you ordered or are you upgrading broadband from Sky?
Yes fibre just found it odd that it wasn't from a short number like EE 150
@Paul8888Openreach do send out these messages to confirm that they can go ahead with the works needed.
