Discussion topic: Mesh Network Issues
Message posted on 22 Aug 2024 07:45 PM
Mesh Network Issues
Hi all,
I wonder if anyone can help, I recently transferred from talk talk 150 to Sky 500. I have a Mercusys Halo H50G mesh network of 4 nodes that worked perfectly in sync on the previous broadband speed, directly from the ONT.
Since I have moved over to sky, the broadband connection is patchy and slow, and continues to drop out and not work, until I go back in to the mesh network and fiddle around.
I have tried using the sky router and creating an access point, as well as missing out the sky router and maintajning the network that was faultless when with talk talk.
Can anyone recommend / suggest what I can try to resolve the problem. Do I need different mesh network technology, is there a setting I can change. I have seen the discussions about DHCP Option 61 field in its WAN configuration, but I am not entirely sure how I check that or it is something compatible with my current mesh system.
Any help or support would be great, as currently, the internet is patchy at best but most off rather than on.
thanks
Message posted on 20 Apr 2025 08:53 PM
Re: Mesh Network Issues
Hi
Did you managed to find a solution to this? I have just lived across to sky using the same mesh network technology as you and seem to be having similar issues.
thanks
Message posted on 20 Apr 2025 09:04 PM
@Ollie8 What mode of operation and the client configuration do you have the wan set for with your mesh.
Message posted on 20 Apr 2025 09:44 PM
Setup as Router with Dynamic IP on IPV4 set on the WAN and set to ignore Ping from WAN.
Message posted on 20 Apr 2025 10:06 PM - last edited: 20 Apr 2025 10:18 PM
@Ollie8 Looking good for that, take it that there is no option 61 MER control on the router, do you also have IPV6 control of any sorts applied, do not know anything about your model as an Asus user.
You may wish to throw up what you are actually having a problem within your system, if you found yhat the Sky router worked ok etc.
