22 Apr 2022 03:32 PM
I have a computer which was connected via LAN using Powerline adapters as I have no wifi adapter in the computer I am using
Had Sky Fibre installed earlier
Wifi providing 100Mb+
Powerline adapters were only giving 25Mb
Openreach engineer said I should not use powerline adapters because the copper splits the signal and should have a mesh hub instead
I don't have a mesh hub and said Sky should provide this - is this information correct?
For info the new router is on the ground floor and my PC is directly above the router in the room on the next floor in a small house (two meters above with a floor/ceiling in between)
22 Apr 2022 03:35 PM
With that speed are you on g.fast or fttp?
If g.fast it is unwise to powerline close to the g.fast mastersocket as the frequencies are similar
22 Apr 2022 03:40 PM
Thanks for the reply
Sky Ultrafast
Not sure what you mean by "With that speed are you on g.fast or fttp?"
22 Apr 2022 03:43 PM
Ultrafast 150 Mbps can be delivered via a modified g.fast mastersocket or an ont
the above is the fttp ont
22 Apr 2022 03:44 PM
Is the connection arriving at a phone socket, or into an ONT (wall-mounted fibre modem)?
22 Apr 2022 03:48 PM
@Anonymous and @cookiemonsteruk
ONT - wall mounted fibre modem
Powerline adapter approx 8 inches away from it
22 Apr 2022 03:53 PM
OK, a powerline network typically won't interfere with that, but older powerline adapters can only hope to shift a small percentage of the speed which it is possible to deliver to an address using FTTP.
22 Apr 2022 03:55 PM
Shouldn't be an issue.
Could you try the powerline from a different port on the sky hub .
23 Apr 2022 10:35 AM
I'm getting 30Mb via powerline, different port @cookiemonsteruk
I noticed the adapters are different make/model so going to switch out one with another so they match up - is it possible because the LAN is moving to different floors that the circuit is different, causing the speed difference?
23 Apr 2022 12:37 PM
Posted by a Superuser, not a Sky employee. Find out more@Pauly+PIf they are all on the same consumer unit thenshould be on the same circuit. The switch out of the different powerline adapters is wise choice. Bit like keeping the same make of tires on a car.
26 Apr 2022 10:08 AM
Posted by a Superuser, not a Sky employee. Find out moreEven if you replace the units with the most expensive ones on the market it may not improve the speed. Powerline is reliant on good wiring, a short run & no interfering appliances connected to the mains. Any one of those points can cause low speed or disconnections. Some homes are just not suited to powerline.
26 Apr 2022 10:18 AM
@jamesn123 wrote:Even if you replace the units with the most expensive ones on the market it may not improve the speed. Powerline is reliant on good wiring, a short run & no interfering appliances connected to the mains. Any one of those points can cause low speed or disconnections. Some homes are just not suited to powerline.
Ideally I wouldn't use anything other than an AV1200 powerline as a minimum for Ultrafast and forget about them completely for any faster connections.
My experience is they are incapable of hitting much more than 200 Mbps even when on the same ring main.
26 Apr 2022 10:20 AM
Its just completely dependant on setup and location. I have a friend who moved into a new build and bought a pair or AV1200's for their 150mbps BT FTTP line & the adapters could only hit about 75mbps. They were better off using WiFi.
