Discussion topic: Maybe map-t problem?
Message posted on 27 Dec 2025 04:36 PM
I've been using openwrt ever since I got Sky and it worked fine. Gave me a public ipv4 all the time. I had to restart the router yesterday and ever since I'm getting a 100. address which is causing problems. I'm use wireguard for my vpn and as well as server/client.
I believe map-t is being used and it has stayed on since no matter how many reboots. I tried the black hub and that seem to have got a public address, I'm a little confused.
I've spoken to a person on cs but they had no clue whats I'm talking about. Can anyone point me in the right direction?
Message posted on 27 Dec 2025 04:46 PM
Re: Maybe map-t problem?
@bdog Why don't you keep using the sky Broadband hub if that is what you have connected?
Message posted on 27 Dec 2025 04:54 PM
I never used the sky hub, I connected it to check what ip it's getting.
I have wireguard installed on the own router and it worked up to the point it started giving me a private address. I've read a few posts and it's generally to do with map-t. I'm wondering if anyone technical can guide me on having it disabled or any workarounds.
Message posted on 27 Dec 2025 04:56 PM
@bdog You just need to work it out with what you have on the connection and the equipment that you are using nothing else to it.
Message posted on 27 Dec 2025 05:47 PM
@bdog Sky can only apply MAP-T to routers that support for DHCPv6 Option 95 which the white Sky Max hubs do and a few third party routers may also support. There was an issue with Ubquiti routers that stupidly advertised support when in practice it did not work. Ubquiti took 8 years to sort this out but did so in a firmware release last year so if tgst could be your problem update the firmware.
Message posted on 27 Dec 2025 06:58 PM
It works fine with the map package installed in openwrt, it created a tunnel for ipv4 traffic to work from ipv6. But I can't seem to get native ipv4 support anymore, it's giving me a non-routable 100.126 address. In turn it broke my wireguard setup.
Message posted on 27 Dec 2025 07:15 PM
@bdog Are you sure that it is not the Router you are using defaulting to a carrier Grade CGNAT type private address when it cannot be issued a wan IP from the sky server! When you put the sky Router back on you seem to be getting a wan ipv4 correct but you do not say if iPv6 is issued also!
