Discussion topic: Matchmaking issues in UK
This message was authored by: DingoSan
On multiple different games I am struggling to find a match on any server. I am watching other users have no problem connect to games whereas sometimes I am waiting up to 15 minutes instead of what should be less than 2.
Re: Matchmaking issues in UK
@DingoSan assuming your devices are otherwise connecting normally it is doubtful its down to your Sky connection as such but you may want to turn off Sky's Broadband Shield if its on at the moment. Another suggestion is to force a change in IP address which can be done by using the disconnect button in the WAN Status pa ge or by powering down for an hour.
@DingoSan
WHat device are you playing on & how is it connected to your Sky hub?
I am NOT a Sky Employee
