Discussion topic: Martin Chick
Message posted on 25 Nov 2025 11:17 AM
Martin Chick
Broadband isn't working in the house but your line is saying everything is ok.....
can you help please
Message posted on 25 Nov 2025 11:19 AM
Re: Martin Chick
@MartinChick
We are customers on here and this is a customer ➡️ customer discussion forum where we try to help other Sky customers. I’m afraid you aren’t communicating with Sky by posting on here.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
