Discussion topic: MacBook Pro channel on 2.4 Ghz
This message was authored by: MD1979
Message posted on 26 Dec 2025 08:21 PM
My MacBook Pro only seems to connect to the 2.4Ghz channel and I can't find any way to change it. Can it be done?
Message posted on 26 Dec 2025 09:13 PM - last edited: 26 Dec 2025 09:14 PM
Re: MacBook Pro channel on 2.4 Ghz
@MD1979 Yes it can, but you need to look on a mac site and the age off your mac book Pro! Then which sky Hub you are using and also the 5Ghz channel that both devices support!
