Discussion topic: MAP-T
This message was authored by: Adele12800
MAP-T
Hi,
I have just recently moved to Sky and have the sky hub max. I work from home and my laptop won't connect to VPN via forticlient and out IT department have told me I need to disable MAP-T on the line, does anyone know how to do this? I have contacted Sky and they tried a couple of things but ended up having to send a form off. I can work on my mobile sim but need to be on Wi-Fi really. Thanks in advance
Re: MAP-T
@Adele12800 you cant disable. MAP-T it hhas to be done by Sky's network team - hence the form - see the post at the top of the forum for more.
