Discussion topic: Low transfers date
This message was authored by: Tomasz8
Message posted on 14 Jun 2025 07:48 AM
Low transfers date
Helo It has had low data transfer for a long time I checked I only have max 320 mbps and it should be 515 mbps that's what it says in the contract
Message posted on 14 Jun 2025 09:09 AM
Re: Low transfers date
@Tomasz8 You need to contact sky if you are 100% sure that your history over the last 30 day's is showing you so. Number below in the need more help so you see it.
