Discussion topic: Low speed
This message was authored by: celt25
Low speed
My iPad has only 6 per cent speed. It's not working for getting into my apps
Re: Low speed
@celt25 6% of what? IPads connect using wifi or in some cases have mobile sims as well. How is your iunit networked? If it is connected by WiFi to your Sky hub are other devices working normally? If tgey are what happens if you move to havectge iPad close to the hub?
