Discussion topic: Low quality internet
This message was authored by: SarahHC
Hi my WiFi seems very low quality, it won't even connect to my phone when I am in the next room. Also I ought to be able to get 5G and it's only picking up 4G. Can you check please, thanks
This message was authored by: Me134
Re: Low quality internet
We're just other customers here I'm afraid so can't check your account. WiFi signals can be very variable, can you reposition the router to a more central position?
5G & 4G refers to your phone signal and is even more of a lottery, especially indoors.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
As @Me134 indicates, those are cellular data signals broadcast from a phone mast somewhere in your local area, and nothing to do with either broadband or WiFi.  The 'G' is for 'generation' of technology and unrelated to the 5Ghz or 2.4Ghz frequency bands of a WiFi signal: to receive a 5G data connection on a compatible smartphone there must be 5G broadcast locally.
This message was authored by: LucasV3
The internet is very slow,  I haven't been able to watch any movies, they keep stopping.
