Discussion topic: Low connection
This message was authored by: Sue_86
Low connection
My boy gets low connection like 35percent signal strength in his room
Re: Low connection
@Sue_86 That may be so, further away you get from the hub the lower the signal strength is same for all!
Avatar for Sue_86
Re: Low connection
Thats what i thought but my other 2 boys are in a room above him and they dont have low connection, i thought it would be other way round as he is closer then they are
Re: Low connection
@Sue_86 Are they all using the same types off devices for the connection or do you have another form of wireless wi-fi boosting device elsewhere that they are possibly seeing?
Next to my AP i am seeing -24dBb signal but the router is on -62dBm about 20' away and through 2 doors and a brick wall, the dinning room for me is at -84dBm Through the floor, ceiling and again about 20' to the right to the other AI mesh!
Avatar for Sue_86
Re: Low connection
He is using a pc rest are using playstations i have no other wifi boosters just the main wifi box from sky
Re: Low connection
@Sue_86 That can be one off any kind issue on the PC, the playstations are good if no problems!
