Discussion topic: Low bandwidth, unstable in Zoom
This message was authored by: HY2
My PC showed Low bandwidth and the network is unstable when I was using Zoom since last week. But when I use the Sky Apps to check the connection, it told everything is fine. It made me can't attend online classes! Any suggestions?
Re: Low bandwidth, unstable in Zoom
@HY2 if youbare using WiFi to connect the PC it could simply be it is toomfar from your Sky hub to get a roliable connection. Rebooting the hub might help,if the issue is due to interference.
