Discussion topic: Low Wifi
This message was authored by: RichardB4aldwin
Low Wifi
Hi,
I have Fibre 500, on our WiFi we currently have 10 devices connected but when I run a speed check on Fast.com the speed is only 16mbps. Doesn't seem right. Any ideas?
Re: Low Wifi
@RichardB4aldwin Try reseting your testing device it may be needing it!
Avatar for RichardB4aldwin
Re: Low Wifi
I am testing it on Fast.com via safari on my iphone
Re: Low Wifi
@RichardB4aldwin Just run a quick test on my laptop, currently reporting 500/80Mb/s connection wise!
Re: Low Wifi
Thanks, I've checked on another device and it is showing better speeds.
Re: Low Wifi
@RichardB4aldwin Good call, always a good idea to try others, i always use my laptop as the phone is just not super reliable at the best off times!
Fast quick speed test!Fast quick speed test!
