Discussion topic: Low WiFi speed
Message posted on 23 Jun 2026 09:38 PM
Low WiFi speed
Very low WiFi speed. Down to 5 mb/s
Message posted on 23 Jun 2026 09:46 PM
Re: Low WiFi speed
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Message posted on 23 Jun 2026 09:50 PM
Re: Low WiFi speed
Mines crashed for the past 5 minutes
