Discussion topic: Low WiFi signal
This message was authored by: Keeks1000
Low WiFi signal
The sky puck is very slow and keeps disconnecting from the sky hub. This has only been an issue since we swapped from BT to sky Internet
Re: Low WiFi signal
@Keeks1000 That will be down to the puck and the hub if you are using both connected via a wireless wi-fi signal!
Sky Stream | Sky Help | Sky.com | Sky Help | Sky.com
