Discussion topic: Lots of buffing
Message posted on 30 May 2026 07:57 AM
Lots of buffing
My WiFi is running very slow and lots of buffering happening
Message posted on 30 May 2026 08:03 AM
Re: Lots of buffing
If the Wi-Fi has become slow see this link
Re: Lots of buffing
@Lisa716 souns lije poor WiFi signal level. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 11 Jun 2026 08:13 PM
Re: Lots of buffing
Same here every day it's so bad can never get through to anyone
Message posted on 11 Jun 2026 08:15 PM
Re: Lots of buffing
I’m having the same issue so cannot be an issue with setup. Buffering every few seconds making stream un watchable
