Discussion topic: Lost wifi connection
This message was authored by: WeeFee-1980
My wifi seems to have cut out, it was working fine then came up on my laptop saying it looks like im not connected to the internet. Can you please help? I am working from home today and need my wifi. Thanks
Re: Lost wifi connection
@WeeFee-1980
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
