Discussion topic: Lost network
Message posted on 12 Feb 2025 03:43 AM
Lost network
I've not had any network/ broadband connection for the last 72hrs.
I've tried the reset within my house thinking it'll reset itself following the online instructions but no luck at all.
Message posted on 12 Feb 2025 05:44 AM
Re: Lost network
@MLawzz
In addition~
▪️ Any engineer visit that’s required is still likely to be delayed due to the disruption from the recent storms.
▪️ This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
