Discussion topic: Lost my sky admin gateway password
This message was authored by: Bruce-Wayne
Message posted on 11 Jan 2025 11:58 PM
I have lost my sky admin gateway password.
admin is the user cannot remeber what the password was set to when it was changed from "admin"
I have check all my usual passwords.
Can the router be reset back to Factory settings ? If So How
Bruce
Find out more
Message posted on 12 Jan 2025 02:19 AM
Re: Lost my sky admin gateway password
Which hub do you have?
The username and password should be:-
Username admin
Password sky or wifi password
If you have changed either then press and hold down the reset button found on the back of the hub until the lights flash
