Discussion topic: Lost connection
Message posted on 13 Nov 2025 06:00 AM
Lost connection
Have lost Internet connection, service checker states no issues in our area, follow steps it states n then it start the next check n then states there is an issue with service checker so stuck n annoyed as work from home today
Message posted on 13 Nov 2025 06:08 AM
Re: Lost connection
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
Quite a few customers have posted about overnight outages.
If it's not back on after 7am, even if you’ve already tried it, use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
