Discussion topic: Loss of bband signal in bedroom
Message posted on 21 Aug 2025 09:37 AM
Just swapped over from talk talk with WiFi all around the house to sky with really bad WiFi dead spots.
Message posted on 21 Aug 2025 09:49 AM
Re: Loss of bband signal in bedroom
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Message posted on 21 Aug 2025 10:59 AM
@johwal61 What did you have TT wise with there hub to what you have now with the sky Hub!
Straight TT hub out, sky Hub in, same position, same connection method?
