Discussion topic: Losing internet connection
This message was authored by: Mel1206
My Internet keeps going on and off
Re: Losing internet connection
@Mel1206
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
