Discussion topic: Losing connection
Message posted on 11 Aug 2024 05:18 PM
Losing connection
My WiFi keeps losing connection to ps5 and PC multiple times a day
Message posted on 11 Aug 2024 08:09 PM
Re: Losing connection
Domestic Wifi has a limited range due to power limits, and is effected by brick/concrete walls, microwave ovens, flourecent light tubes. If you look outside at the houses around you, you will see the TV aerials are placed on the roof, to get a clear signal.
Where are the wifi aerials on the computer ? (Please dont say on the back of the computer blocked in by the computer case/faraday cage).
Where is the ps5 in relation to the sky hub?
If the PC and Computer cannot move, can the router be moved closer?
Can the PS5 and Computer be connected by long ethernet cables?
