1
This discussion topic has been answered Discussion topic: Loosing internet connection
This message was authored by: Derek49
I lose the internet connection, what happen? Could you please check? Internet light is off, voice light is red, others are green.
Re: Loosing internet connection
@Derek49
We can't check. You haven’t actually contacted Sky Customer Services by posting on here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
@Derek49
