Discussion topic: Long buffering time
Message posted on 24 Nov 2025 09:19 PM
Long buffering time
Message posted on 25 Nov 2025 08:21 AM
Re: Long buffering time
@Benproff most common cause is poor wifi signal level. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
