Discussion topic: Lg tv issue and error
This message was authored by: LYNN1978
My tv is dropping a connection constantly so cant update due to connection issues or open apps ? And its saying there is no issues.
Re: Lg tv issue and error
@LYNN1978 sounds likecthe TV is not getting a decent WiFi signal. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
Avatar for LYNN1978
Level 0 icon
It is only one device that is being used ?
@LYNN1978 WiFi signal level does not depend on how many devices are in use.
