Discussion topic: Leeds Broadband Outage
Message posted on 12 Jan 2026 11:54 PM
Hi, Is anyone in Leeds having issues with no Broadband, today the 12th,.specifically in the area around Bowman Lane, Hunslet?
Message posted on 13 Jan 2026 03:59 AM
Re: Leeds Broadband Outage
@Mustman1959
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Message posted on 13 Jan 2026 04:28 PM
It was an area outage, that promptly was fixed around 10:30 this morning, by Openreach. Unfortunately I still dont have BB. The hub is displaying 2 green lights, power and WiFi, red voice light and no Internet light on, even after various reboots. Sky are sending an engineer out tomorrow to have a look at it.
Has anyone else had to have a follow up engineering visit after an external area BB outage?
Message posted on 13 Jan 2026 05:52 PM
@Mustman1959 it is not that unusual as depending on what caused the outage and whether you have a connection using coper or full fibre. For example partial fibre connections over copper can have issues caused by over voltage etc.
Message posted on 13 Jan 2026 06:28 PM
Hi @Chrisee Thanks for your input. The feed is fibre to the cab and copper on the d side.
Hopefully the Sky engineer will fix the issue and not send it back as a network issue 🙄🙏😉
