Discussion topic: Lagging connection!
This message was authored by: T.+Russ
Lagging connection!
Anyone's else constantly getting a 'lagging' Wi-Fi  connection after 10pm? I run checks and all is fine. So frustrating! Videos on phone constantly just trying to load.
Re: Lagging connection!
@T.+Russ the most likely cause of a connection starting to lag is WiFi interference which can be caused byba neighbours's network using the same or adjacent WiFi channel in which case reboot your hub when the issue is present as thst should sort it. Hiwever interference can be caused by different things some of which a feboot wont sort if that applies then consider what switches on in your homexaround that time. Sources can be a dodgy light, microwave etc.
