Discussion topic: LOS red light
Message posted on 05 Jan 2026 03:39 PM
LOS red light
Everything was working fine all of a sudden the internet went down.
I have the fiber cable going into the openreach modem that connects to the Sky router via Ethernet cable.
The LOS red light is on the openreach modem.
Message posted on 05 Jan 2026 03:46 PM
Re: LOS red light
@Nawaba1 the ONT (not really a modem but does a similar job) is showing it isnt receiving an optical signal. Asuuming the green fibre pigtail cable is not lose you need to call Sky as it requires Openreach or City Fibre to check what is wrong and fix it
LOS = Loss Of Signal.
Message posted on 05 Jan 2026 03:50 PM
Re: LOS red light
@Nawaba1 And the sky info link if that is needed for you!
