Discussion topic: LOS Light Siro
This message was authored by SD. This message was authored by: SD.
LOS Light Siro
I recently got 1gb fiber with SIRO Installed. Tonight, my siro LOS light is flashing red and has been for 2 hours..
Has anyone had any luck with this been resolved?
Re: LOS Light Siro
@SD. if the connection test in the My Sky app run over a mobile does not idicate a known issue suggest you call Sky when their lines open.
