This discussion topic has been answered Discussion topic: LAN showing red
Message posted on 17 Mar 2026 02:42 PM
LAN showing red on box and no wifi to the house
Message posted on 17 Mar 2026 04:01 PM
As your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
Message posted on 17 Mar 2026 05:59 PM
Re: LAN showing red
If it's the LAN light on the ONT then there is a problem with the cable connecting the ONT to the router. Make sure it's plugged in properly and undamaged. If that doesn't help, try a different cable. Any cat 5e/cat 6 cable will do.
Message posted on 17 Mar 2026 08:24 PM
Re: LAN showing red
It's actually the LOS light that's red
Message posted on 17 Mar 2026 08:43 PM - last edited: 17 Mar 2026 08:48 PM
Re: LAN showing red
@Jkw1 Then the LOS Red is a call to sky, they will organise OR/CF which ever one your Fibre is with to see what is wrong, you can try the ONT power off then back on again about 1 minute later, and if LOS stay's Red you need to call sky, 8am to 8pm so tomorrow morning now!
