This discussion topic has been answered Discussion topic: Kit return
Message posted on 27 Apr 2025 10:32 PM
Hi, I've just updated to a white router and need to send my black router back, can I use the packaging the white one came in?
Message posted on 27 Apr 2025 10:43 PM
Yes, under the box that holds the white hub, within the exterior box when you remove the smaller box there should be a return label underneath that you can use to return via the post office
take a picture of the label and make sure they give you the tracking details
