Discussion topic: Keep losing internet
This message was authored by: Ehl
Have checked the service and it says no known issues, but there is i keep losing WiFi and my heating is connected to WiFi and I can't change my heating setting because it won't connect.
Re: Keep losing internet
@Ehl
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
