Discussion topic: Keep losing internet connection
Message posted on 07 May 2026 11:02 PM
I keep losing internet connection. The lights on my router turn orange, then a approximately 30 seconds later turn back green. I have tried to use the sky service checker, and it says everything is working fine.. however I'm looking at a tv screen that says no internet connection and a router full of orange lights.. it's clearly not working fine.
Message posted on 08 May 2026 04:05 AM
Re: Keep losing internet connection
@Clarelou100
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
